is a gefrce 2mx ok without a fan?
wildone
Senior Member
TN
I just got a anhilator 2 mx for a friend that is an oem version without a fan,I just need to know if its gonna be ok by design or does it have to have a fan,it WONT be OCed,,,,,,,,,,wildone
Yes, it'll be ok if you don't overclock the card. However, it's easy to find a cheapie 40mm fan that will fit right onto the GPU heatsink. An old recycled 486 CPU fan fits perfectly.
