Been having a problem for a while with my video card, I bought witcher 3 knowing the recommended hardware requirements (only having a single 760 OC DC2), no problem i could live with not complete full graphic settings. The problem arose when i started to OC the graphics card to try and bump up the settings, thats why i bought a decent 760, well sure enough it kept crashing due to some windows driver issue so i just used it at stock settings. The biggest problem is when playing fallout 4, i've had to drop the settings to high because i keep getting horizontal lines and stuttering.
Knowing i have a little 760 i was planning on upgrading but will have to save for a bit, ideally a 980ti or used titan x.
A local seller has a reference gtx 760 for sale for $100 CAD, the cheapest i've seen them yet.
So aside from my system throttling one of the cards to keep them even is there any reason that I shouldnt take this deal?
I figured for $100 this should fix my problem until i upgrade to a expensive card (minimum May or June 2016)
What do you guys think?
