- Jun 10, 2002
- Los Angeles
I remember reading posts that said to clean out your loop using CLR if you get gross buildup and it also helps to use it to flush out the res.
I wonder though, is CLR safe for the inside of my plastic pump? It won't eat away at the rubber o-ring or make the plastic weak will it?
