is expensive memory worth it?
Sneak
Thunder Bay, Ontario
I dont want to overclock so overclocking capability doesnt matter. I just want to know does it really matter if I buy some generic memory instead of like crucial. Will I really notice a differance?
I want sdram not ddr.
CSaddict
CT, USA
If you are keeping the machine stock then generic memory will mostlikely serve the purpose. P.S. Welcome to the forums
Wolfmist
Chicago, IL
People have had problems with getting cheap generic memory. There's a greater chance you'll have stablility problems if you get generic. Though I've never bought from crucial, I would recommend getting from them rather than some cheap memory from someone else.
Kato
Addicted Tweaker
Toronto, Canada
Crucial has reduced their price, 256Mb PC2100 now only $69 on their website, so if cheap generic has the same price as Crucial, why even bother buying generic?:D
edit: darn, the price went back up to $85.49 again....:eek:
WyrmMaster
I'm a little teapot Senior
Montana, USA
If you dont plan on overclocking at all you shouldnt have any problems with generic. Make sure you buy from a place that you can return it to if you DO have problems though.
