- Jul 24, 2017
So I am new here and joined this forum to learn more Good Things.
I have Mafia III and getting problem with it. I know I have low-end PC but the people who have high-end PCs also facing some problem.
Anyway, I decide why not overclock GPU a little and finally the game is playable.
My Rig:
Intel Core i3-4130 - 3.4 Ghz
Gigabyte Geforce GT740 2GB OC Edition (Graphic Driver Updated to latest)
https://www.gigabyte.com/Graphics-Card/GV-N740D5OC-2GI-rev-10-11#ov
16 GB - DDR3 1600Mhz
Windows 10 Professional x64 (Fully Updated)
Here are two pics, in which you can see the same. Note that this pics taken when I was not gaming so card is not using the full GPU Clock and Memory Clock.
Also in NVIDIA control panel, I made little changes for (MAFIA III) as per below:
1) Antialiasing Mode - Set to "OFF"
2) Power management mode - set to "GLOBAL"
3) Vertical Sync - Set to "OFF"
My question, did I do right or wrong? Someone says that if you turn off Vertical Sync off then card will FRY but after 3 days of gaming (around 8 hours continuous playing per day), The card is still stable and game like MAFIA III, Sniper Ghost Warrior 3 and Just Cause 3 are working fine.
If I did wrong then please let me know, so I will do it correct manner.
My Rig:
This card is OC Edition and the Factory settings as below:
GPU Clock showing 1072 Mhz
Memory Clock 5000 Mhz
I slightly overclocked it to:
GPU Clock 1072 Mhz + 50 Mhz = 1122 Mhz
Memory Clock 5000 Mhz + 12 Mhz = 5000 Mhz
