Is it possible to get a bigger fan on a 50mm heatsink?
What about a 92/80mm to 50mm fan adapter/reducer
Thats kind of what i am looking for but I haven't found any for 50mm, i have found a bunch for 40 to 60 and 80 to all manner of sizes above it. I'll keep hunting with the word "reducer" because i didnt know the terminology before
That's kind of what my seach came back with. I also noticed 3D printable if you have access or a friend maybe you could make one custom
Thats a good idea i do have access to people with 3D printers
Are there after market coolers available for that socket? I'm thinking probably not since it's a server board.
I'm a little late to the thread but have you hopped online and looked at your local makerspace? (the 3d printer guys usually have a dedicated building/space for meeting up and hanging out. If you hook up with them you can get someone to 3D Print an adapter for you.
I made my own adapter (50mm to 30mm) for my MP Select Mini that works great.
I am considering this board right here: https://www.newegg.ca/Product/Product.aspx?Item=N82E16813182964
However I read the 50mm fan is stupid loud so I was wondering if it is possible to rig something up with lower rpms but more airflow.
Appreciate any and all feedback
A fan reducer will not work as you expect. I did a number of experiments on fans with reducers and what I discovered is that a bigger fan blowing on a reducer loses a lot of its air flow because 90% of the air is moved by the outer part of the fan. But the outer part of the fan is blowing on the sides of the reducer. The sides of the reducer then reflect the air away from the downward direction and actually impede the flow of air towards the heat sink. Worse, the center of a bigger fan is usually blocked by a bigger hub and you get even less air going down the center. In effect, the reducer will make the airflow less than you would have had with the 50mm fan. The reducer also increases the back pressure against the flow of new air into the reducer and makes it even harder for air to reach the heatsink. Finally, a fan is most effective when air turbulence is close to the heatsink's surface because turbulence causes a lot of air to hit the heatsink fins and extract heat. A fan placed well away from the heatsink will not have turbulence but instead it will produce a more laminar flow which had dramatically less heat removal ability.
A better option is to use two fans on the 50mm heat sink. The fans are glued side by side and placed so the two hubs of the fans are over the edge of the heat sink. This way you get maximum air flow at the center of your heat sink. The two fans can be used at slower speeds because the airflow through the heat sink is greater, and the two fans cool other components outside the cpu heatsink. In that configuration I would recommend reversing the fans so they suck on the heatsink and remove hot air as soon as possible. Add a duct made of cardboard above the fans and you avoid churning of hot air back into the fans.
Here is some more info on fan configurations:
http://www.overclockers.com/forums/showthread.php/344236-Fan-CFM-loss-due-to-fan-adapters
http://www.overclockers.com/forums/...ool-amp-quiet-3-84ghz?highlight=parallel fans
http://www.overclockers.com/forums/showthread.php/319423-Heat-sink-fan-comparison-tests
how about your choice of two of these https://snakeclamp.com/ and a pair of yate loon 120s or 140s. That should keep the whole board chilly. i did something similar with an 80mm heatsink. i pulled the 80 and replaced it with a 120mm on a goose neck connected to the case. i ran it that way for 3 or 4 years before upgrading the rig.
