- Nov 10, 2008
i can picture an intel cpu painted black with a scythe stuck to it, ready to take your processor at the slightest whiff of static electricity
Instead, nothing happened despite repeated attempts to zap the compter. It turns out its not so easy to kill a computer even with high voltage statics.
All I can picture is a pb&j with the chip inside.
Interestingly we used a Tesla Coil to zap an old PIII computer, its keyboard and mouse. Static lightning bolts struck the metal keyboard, hit the case and the power supply. We all thought the machine would die an immediate death. Instead, nothing happened despite repeated attempts to zap the compter. It turns out its not so easy to kill a computer even with high voltage statics.
That story is is kind of fishy your phone is fine but the static mess up your pc, it just traveled through your phone to the usb then to your pc, not buying that story at all.
I cant keep count on the the mother board i've shocked some are from customers with new P3's i built in the past still running strong.
When i purposely shock chips to death with high voltage and low amps so it wont leave any burn marks there is no bumps on chips.
Yes it's really static were a build computers after the first 10 times i shocked motherboards and pc chips and nothing went wrong it got me curious.
The antenna on a sell phone goes to the output and receive transmitter on the phone it's electronic. you proved it your self and other people have also static does not kill phones or ipods.
When i do shock testing for fun with micro chips, i do it right over the pins on the bottom of the chip and some shocking with the chips on a soldered board, the chips get vary hot with 80,000 volts coursing through them but it takes hours to kill them and it leaves no burn marks or bumps so you could warranty the items.
Well the sparks from the coil runs all over all the chip's pin's and the chips get vary hot so it's penetrating the micro chip, also i hold the electronic items' on a metal grounding surface, 80,000 volts would burn your nervers in your hand.I think I understand what you're saying in the 1st 2 paragraphs, but the wording/grammar/spelling is making it difficult.
As for the 3rd paragraph...
You can point your shocker at the pins, but you can't be certain the charge is actually traveling through the delicate components. Electricity will always take the easiest route to ground, and that might involve going around directly to the IHS. Again, how are you holding the chip? In your hand or in a metal vise, etc?
You could ground one or several of the pins, and then shock the other pins. This would most certainly force the current through the delicate components (if you can keep the sparks from jumping straight to the grounded pins across the surface of the chip package), and you could probably go on a chip killing spree in the same amount of time it's taking you to kill 1 chip.
So, let me get this straight...you purposefully spend hours of your time killing chips, and do so in a manner so that no one can tell you've been purposefully destructive. Only to then RMA them for free replacements at the manufacturers expense?
I really hope that is not what you are saying...
Well if it was not working correctly from the beginning it wont work at all when i get done with it LOL.So you spend your free time breaking things in an undetectable fashion that are already broken?
How do you know your process actually damages something if it was already broken? Conversely, what if they could fix the original damage but not whatever boneheaded shenanigans you come up with?
