- Dec 14, 2010
Think I may have the upgrader's itch again.
I built my current main PC in 2015 (with various updates and upgrades over the years), and feel like I'm leaving some potential performance on the table (for my GPU specifically) by running hardware from four (or five) generations back. I think the older CPU and motherboard architecture may be holding back or bottle-necking the GPU. Main reason for this concern is I swapped from GTX 1070 to a GTX 1080 and didn't really see much performance gain at all, barely noticeable. Inverse was also true, going from a 1080 to a 1070 I didn't see much of a performance loss at 1080p with the same settings in-game when I was playing Battlefield V.
Current config:
CPU: Intel Core i7 4790K (started with a 4690K, but upgraded it)
Motherboard: ASRock Z97 Extreme6
RAM 2x 8GB G.SKILL Ripjaws X 1866MHz
SSD: Samsung 850 Evo 500GB
HDD: WD Caviar Black 1TB (running low on space, 285GB left)
Cooler: Corsair H100i GTX/V2 (seller said it was a V2, but Link software says it's a GTX?
) I had an H110i in it before, but that didn't play well with the RMi series power supply and caused the board to stop reading the PSU if both were plugged in to the board via USB (and CPUID HWMonitor stopped working if both were plugged in as well. Another weird thing was that the AIO's fans did this thing where they would ramp up and down in fan speed before going to max speed and staying there IIRC.).
PSU: Corsair RM650i
Case: Corsair 750D
I've done some research, looks like an i5 6600K would be a downgrade of between -8% to -20%, i7 6700K would be a sidegrade or very slight performance upgrade of ~2-5%. Core i5 7600K would be a slight upgrade or large downgrade (depending upon what site you believe), maybe on the order of 5-7% more performance (or 20% less) which for the upgrade cost of $400+ probably wouldn't seem to be worth it. Core i7 7700K looking like a 10-21% performance upgrade, but $500-550+ for said upgrade. Core i5 8600K between 1-20% upgrade for $500+.
Looked at X99 briefly before realizing the platform was nearly as old as my Z97 setup. Core i7 5820K is between -1% to +10%, i7 5930K is a 3-19% upgrade for probably $350-450+. Core i7 6800K 2-24% upgrade (unknown upgrade cost, haven't checked), i7 6850K 10-29% upgrade (unknown upgrade cost, haven't checked).
Current config:
PSU: Corsair RM650i
Case: Corsair 750D
