- Nov 15, 2008
- San Deigo, CA
Hello,
I was given a super duper tight budget of $350 to build a light gaming rig.
: even looking into classifieds this is nearly impossible to put together a decent used machine with case and all.
So..... I was thinking.. I have some very ancient parts sitting in my closet collecting dust... I found old and dusty GA-EP45T-UD3P with a lapped CUP... I think it's an E8600 that I had lapped but can't verify it anymore as I no longer have a PSU or proper HDD to test it. It has some writing on one of the sides (N391106 and 2/1663) got no clue what that means. Maybe someone here that can decipher those intel codes? It also has 4X1GB Crucial DDR3 so I was thinking if I just donating my old hardware and focus on buying a decent GPU/PSU/SSD and possibly update to 8GB of Ram if there was some money left over? I have an old case that I can just give it to him along with the motherboard/CPU/RAM.
I was browsing around and found ASUS GTX 770 Direct CUII for around $100. Then maybe a used PSU for $80-100 , 120GB SSD for $50, CPU cooler for $30 and call it a day? possibly get 8gb RAM that might work with dusty EP45T-UD3P with the left over budget?
Would the E8600 (I'm hoping that's the CPU) be too much bottleneck to play decent games at around 60fps if pared with GTX 770 at maybe 1080P resolution? I think most likely he is going to be using a 40-50in LCD 1080P TV as the monitor.
Or... do you guys suggest I scrap the above idea and just go with something modern for CPU/MO/RAM combo? something low end like G4520 that I can get for around $60 and get one of the cheap ITX motherboards for another ~$60? would that combo be better than old E8600+P45 motherboard?
Thanks for your suggestions.
