is my audigy dead?
P2P
hi just outa the blue my soundcard seemed to die
when reinstalling it xp finds hardware as emu100 i guess that an emulator
when i try to install audigy drivers it reports that there isnt an audigy card in my system plus the firewire wont install either
any ideas on this ?? fixxable????
thx
Tebore
Toronto,Canada(I can see you....)
Try moving the card to a different slot. Also try removing the drivers and remove from hardware manager, shut down, take out the card boot, shut down, reinstall the card and let windows detect it.
