Hi,
Im running:
STANDARD BIOS SETTINGS - NOT Overclocked
board: km266pro-8235 (has most recent driver)
cpu: amd athlon xp 2400+
memory: 1gig kingston ddr pc 2700 333mhz
hd: maxtor diamonmax20 80 gig 7200 rpm
cd-rom: hl-dt-st cd-rw gce-8160B (has most recent driver)
psu: enlight gps-250ab-100L
psu(secondary): antec pp-303x 300w
video/display: radeon 9800 256MB GDDR2 (has most recent driver)
audio: stock onboard audio (has most recent driver)
Memtest results = standard scan 12 passes - no fails
comprehensive scan 2 passes - no fails
Prime95 results = [Sun Mar 23 02:02:36 2008]
FATAL ERROR: Resulting sum was -3.41829454555409e-005, expected: 104429803759.4056
Hardware failure detected, consult stress.txt file.
Torture test ran 0 minutes -1 errors 0 warnings.
Temperature (using SPEEDFAN) - never passes 54C even during application/games
(normally stays around 47C-50C)
IDLES around 30C-40C
Basically, no matter what type of application I run, it will FATAL. Giving me an error message along the lines of "0xC0000005 (ACCESS_VIOLATION)...."
This error happens not only during use of IE, Crazybrowser, VLC media player. GOM player, Windows Media player, Warcraft 3: TFT.
ALL THE APPS are legal, none are cracks. The access violation never changes always 0xC0000005. ALREADY TRIED http://www.updatexp.com/0xC0000005.html
, just not the FULL DEP DISABLE.
VIRUSES: I have reinstalled Windows XP home sp2, at the minimum 5 times. And immidiately after scanned for viruses, and installed firewall/antivirus software. Even when i recieve the error, i show no signs of a virus.
Registry: I have checked my registy at the minimum of once a day, using GLARY UTILITIES or S&D spyware/registry cleaner.
HARD DRIVE: i've ran error checking and defragging at least 3 times each, with no errors for Error checking.
PSU: I used to run just 1 power supply, but i saw some people saying stuff about "not enough power being a problem". SO i started using the secondary PSU for my hard drive and CD-ROM, and the primary for motherboard and Video Card.
PLEASE, someone help me, i dont know what else do to, because I can't acquire a replacment mobo or cpu for now. I need this FATAL 0xC0000005 problem resolved.
Im running:
