- Dec 7, 2003
- Portland, OR usa
clocker2 said:CCW,
Is that based on personal experience or just assumed "common sense"?
After extensive testing on my case, I found that having all of my fans act as intakes and leaving the exhaust up to passive venting worked the best for me.
I have to chime in and agree here.
I'm not totally sure, but I believe where there is considerable impedance (small vents or a cluttered case) you might be better off with an intake and an exhaust fan. Axial fans can't fight impedance (air resistance or back pressure) well.
However, if the impedance is low, you should get the best airflow by having all your fans to either intake or exhaust - if they are mounted where it is sensible to do this.
You'd want to plan your airflow and make your vents so the air goes where you want it of course ...
the wesson
