- Dec 29, 2000
I'm posting this because I'm a little worried, just recently, my mobo monitoring utility has been bugging me saying that my CPU is running way too hot... it says it's running at 80 degrees celcius! I know this is EXTREMELY hot, but I have reason to believe it's not really running that hot.... I'm just asking if you can help justify my reasoning...
a.) surely if the CPU were running @ 80c it would have fried by now
b.) SURELY if it were running @ 80c my system would be unstable/random lockups
c.) I've used an instant-touch thermometer on the top of the heatsink under the fan RIGHT up against the CPU and it read 30c
d.) the air moving through the fan is barely "warm"
e.) If I underclock/overclock the CPU, the temperature doesn't change at all, no matter what the circumstances (I've underclocked it 300mhz without change in temp)
Now really, the sensor for my CPU, is it bad? I mean, I can't really be running that hot, it was running at 30c before this happened perfectly fine with the OEM sink/fan on it... and that was overclocked! This just SUDDENLY happened one day... so, can you justify my belief of the sensor being screwed up?
Thanks in advance
Thanks in advance
