Hey all, this is my 2nd post in a very long time.
Ok to start off I will give you my pc specs ok
Windows Vista Ultimate 32bit edition
Intel Core2duo E8200 2.66GHz
Kingston HyperX 2gb 800 DDR2 x2
Asrock P45DE P45 FSB 2000 PCI-E 2.0 4xDDR2 1200
Seagate Barracuda IDE and SATA both 7200RPM
Element series ST75EF Silverstone PSU 750Watts
And finally Galaxy Geforce GTX 260+ OC 896MB 448Bit DDR3, Core clock 625MHz, Shader Clock 1350MHz, Stream Processors 216.
Now here's the story ok before I got my Silverstone ST75EF 750Watt I was running on a Silverstone SST-ST50EF PLUS 500Watt PSU, now last week I introduced my new purchased GTX 260+ http://www.galaxytech.com/en/product.aspx?serial=14 into the system yeh with the Silverstone SST-ST50EF Plus http://www.silentpcreview.com/article670-page1.html. Now probably my most stupid think I did was run it on the minimum 500Watt on C16xQ Antialiasing in Supersampling, in games like Streetfighter 4 and Mirrors Edge with 16x anisotropic filtering. At the start this was great on the 500w psu, then my Samsung Syncmaster 2693HM 26" LCD monitor starting turning off then the blue led light would just blink on and off, sometimes the system would still be running sometimes it would pause up and reset itself. Also sometimes the screen would turn dark blue or white then pause up with no text unlike bsod. I put my power plan in balanced and went throught the entire drives with disk checking tools and malwarebytes anti-malware updated and avast antivirus scanner updated and found no nasties. Also my nvidia driver is 190.62, and all direct x 9.0 is updated along with all the windows vista updates. So after this starting happening I quickly got onto ordering the Element series ST75EF Silverstone PSU 750Watts, but I hope it wasnt a little to late cause I still sometimes suffer from the same things that plagued me when I was running with the 500watt PSU with my new Silverstone ST75EF 750Watt. Sometimes I get lucky and the pc will run for hours even when playing Mirrors Edge and SF4 with Multisampling at C16xQ I decided to turn down from Supersampling to Multisampling in hope that wouldn't overdo my card and reset. Now i haven't updated the motherboard bios at all so would any of these updated bios help http://www.asrock.com/mb/download.asp?Model=P45DE&s=775. Also I do run GPU-Z and read the sensors when I start up a game etc
In windows vista no game run
GPU Core Clock [MHZ] 300
GPU Memory Clock [MHz] 300
GPU Temperature [°C] 39
PCB Temperature [°C] 39
GPU Temperature [°C] 31
PCB Temperature [°C] 32.5
Fan Speed [%] 40
In game with multisampling/supersampling with C16xQ
GPU Core Clock [MHZ] 625
GPU Memory Clock [MHz] 1050
GPU Temperature [°C] 41
GPU Temperature [°C] 33
PCB Temperature [°C] 33.5
Fan Speed [%] 40
I can't figure out anymore I need to tell you, other that I defrag my drives each day, run malware/virus scans, watch my GPU-Z temps, maybe I should be using a utility to tell you what my voltage load is on my 12volt rails perhaps. Oh also my kingston hyper x ram is in dual mode.
So back to the title of this thread is my Galaxy geforce gtx 260+ broken, if so what the warranty usually on those things I can't find it anywhere on the galaxy website.
Thanks
Mark
Fan Speed [%] 40
Fan Speed [%] 40
Thanks
Mark
