- Feb 27, 2011
Here are my computer specs:
OCZ 600 Watt StealthXtreme OCZ600SXS
Core 2 Quad Q6600 (G0 stepping)
Asus P5Q-E
2 x 2GB DDR2 1066
Auzentech Prelude sound card
250 GB WD Caviar Blue WD2500AAJS
Geforce GTX570
Samsung sh-203n DVD multi writer
2 x 120mm fans
1 x 90mm fan
I used to have a Geforce 8600 GTS but I am now upgrading to a Geforce GTX 570 GTX (yes I know my Q6600 will most likely be a bottleneck but I can't afford to build a new system right now) and I was wondering if my current power supply will be powerful enough or if I should upgrade it.
I'm pretty sure I have enough wattage, my main concern is can my PSU supply enough amps?
EVGA recommends 38 amps on the 12v rail and my PSU has 4 rails supplying 18 amps each. That's the way I think it works anyway please correct me if I'm wrong on that or any of this.
According to wikipedia a 6 pin power connector can output a maximum of 75 watts. That would mean each 6 pin connector would need 6.25 amps then because amps = watts / volts. If that's true then that's well below the 18 amps that each rail provides so it should be fine I would think. This mechanical drawing shows that the PCIE2 connector shares the 12v2 rail with the CPU power cable. The max TDP for a Q6600 is 105 Watts and this review shows that the Q6600 was using 102 watts. Going with the higher of the two the Q6600 should require 102 watts / 12 volts = 8.5 amps. According to the mechanical drawing the cpu power plug is connected to both the 12v1 and 12v2 rails so if the cpu was getting all it's power from that plug it would need 4.25 amps (8.25 amps / 2) from 12v1and 4.25 amps from 12v2. The only two parts of the GTX570 that have a risk of not having enough amps are the PCIE2 connector (because it shares 12v2 with the CPU power plug) and where it connects to the motherboard. If my previous calculations are correct though PCIE2 shouldn't be a problem because 4.25 amps (from the CPU) and 6.25 amps (from PCIE2) is 10.5 amps which is well below 18. And that's worst case scenario because I'm guessing that the CPU gets most of it's power from 12v1. That leaves the motherboard connection of the GTX 570 that might not have enough amps.
So to sum it up does my power supply have enough watts and does it have enough amps? I asked this question on the Tom's Hardware forum but I didn't get the technical answer I was hoping for. Could someone please tell me if my calculating everything right, I don't have a strong grasp of physics.
Asus P5Q-E
2 x 2GB DDR2 1066
Geforce GTX570
2 x 120mm fans
1 x 90mm fan
