Is my ps adequate for this setup?
dicecca112
MA, USA
assuming if a standard 120mm radiator would fit: 172x124x50mm centered at the 120mm fan hole (go and measure);
1. get the thermochill HE120.1 radiator from dangerden.com $85; don't forget the 1/2 barbed 3/8-bsp thread fittings $5
2. get the *TWO*CSP 750 pumps from dtekcustoms.com $72
http://www.dtekcustoms.com/index.as...PROD&ProdID=140
3. get the TDX block from dangerden.com with the brass top and 1/2 barbs, OR get the MCW6002 from a retailer that sells swiftech; TDX is should be a bit less restrictive $45-60?
4. you need: 10ft of clearflex hoses; see the usplastics people, GOOD antifreeze; see your local automall, and also one of these: http://www.dtekcustoms.com/index.as...PROD&ProdID=130
and 120mm fans for the radiator, distilled water (aquafina at the grocery store, MUST BE AQUAFINA, NOT MINERAL WATER), and quite a few zip ties
