- May 12, 2012
First, the situation: I have my ssd set up as my gaming drive (steam/mmo's) and everything had been normal until I went to open steam and the entire computer froze. This is abnormal in and of itself. Its been smooth as butter since I built it just shy of a year ago (will be a year at the end of March). Tried to reboot, and Windows (7 Ultimate) wants to repair, and both that option and trying to load normally going into infinite loading screen mode. The only way I can get it to boot is by cracking the case and unplugging the sata3 cable from the ssd itself.
Relevant information:
Proc: I5 3570k
Mobo: ASRock z77 Extreme 4
Mem: Kensington Hyper Red 16gig @1600mhz
Gfx Card: Gtx 680ti (Zotac)
Power: KingWin Lazer Platinum ATX 850 Watts 80+ Platinum
HDD: Western Digital 1tb (Blue)
SSD: Samsung 840 Series (SSD) 250 GB Sata
Mobo is throwing 4f, 62, 99, a2 as errors on startup, which all point to sata devices.
So, questions!
Anyone have a clue as to what is actually wrong, and if it is fixable? I really do not know where to begin. Could it be the power supply? I mean the mobo is tossing those errors even with the sata unplugged (I believe it was throwing more when the sata was plugged in, I can check if you would like). Is the drive just fried? Is there something else I can do? Any help would be appreciated.
Proc: I5 3570k
So, questions!
