- Apr 25, 2003
- Huntington Beach, CA
I recently went AMD. I got an Abit NF7-S v2 and a Barton 2600+. The processor is watercooled via a Corsair HydroCool 200 system.
My memory is just standard Corsair, good but inexpensive, and the memory timings are kept low.
Anyway, I'm running bios 21. My FSB is set to 225, 11x multi, 1.85v core. This leaves me at (according to the bootup screen) 2464mhz. The divider has been changed so the ram is only running a couple mhz over it's native 333.
At idle, it sits at about 38c, and hits 47c under load while running Prime95 after a few hours.
It can run Prime95 all night with no problems, and in SiSandra it benches better than the xp3200 and the P4 3.2c.
Now, the results seem decent, but I'm worried about the temps. Is that too high for idle / load on an AMD? Is the motherboard sensor on the NF7-S v2 not entirely accurate? Are there any other settings (FSB/Multi/vcore) I should try for netting the same / better results with lower temps if they are too high?
The FSB will go a little higher if I lower the multi (to about 235), but I figured it would be better to put a little more of the load on the CPU, since it's the watercooled component.
Anyway, much thanks!
PS - Running Windows XP btw. Radeon 9800 / SB audigy2 are addin cards, using onboard network.
Edit - I thought I should also add that I haven't gone any higher because of a) the temps, and b) it won't do any higher vcore than 1.85 and be stable, or even boot most the time.
