- Jan 12, 2005
- UKbiquitous
Hi,
I'm using an A64 3700+ San Diego on an ASROCK Dual SATA2 motherboard, cooled by an Akasa AK-913 with 1 akasa branded 80mm fan pushing through it. I've also got 2x 120mm thermaltake case fans.
Using MBM I can acquire 2 temperatures so I assumed that the highest one is the core temp. However, when I was using my previous setup of a 3000+ Barton and a Volcano 11, temps were on average around 12-14 degrees C higher.
The ambient temperature of my case ranges throughout the day and night - my room is organised like this:
||Window|| ---- ||Case on floor|| ---- ||Monitors on desk|| ---- || Rest of room||
I use the monitors to heat the half of the room that I sit in because they are like little radiators they heat up so much. They almost provide a 'wall' of heat, so where I am sat is warm, but anything on the window side is cold. This leads to ambient temperatures of between 17 and 23 degrees C, depending on how cold it is outside, and my idle/load temps range from 23/26 to 28/32 depending on how open the window is. My box is on the floor on the window side of my monitors, so it doesn't get warmed at all.
What I'm trying to ascertain is if this is realistic for my setup, or whether the sensors are inaccurate. Could anyone give me a clue?
Thanks.
Thanks.
