- Nov 16, 2009
I got the P5Q-C, planning on buying the TWIN2X4096-6400C4DHX...problem is...
The QVL say's its compatible, Corsair's 'Will it work on your mb' system doesn't even have my motherboard in it's listing...confusing already...now.
The JEDEC standard @ 5-5-5-18, BUT ..
"was tested at latency settings 4-4-4-12 @ 2.1V" according to Corsair...
Does it mean the modules need 2.1v or the JED is 1.8v and if i want the lower latency i need t manually set the voltage and the latency?...
thx.
thx.
