is the ASUS P4 S478 P4P800/GD ATX Moederbord and good
DaRky4YoU
id like to know if this baord is any good at overclocking a p4 2.6 c or a p4 2.8 c, and if the pci is locked or sometihng like that since people say its important
Artikelnaam: ASUS P4 S478 P4P800/GD ATX Moederbord
Specificatie:
P4P800/GD
ASUS Intelligence Everywhere
800FSB/4GB Dual-DDR400 Memory
Intel 865PE Chipset
800 MHz FSB
Dual-Channel DDR400 Memory
Intel Hyper-Threading Technology
ASUS Intelligence Features
AGP 8X slot
3COM Gigabit LAN
The World's First Motherboards with ASUS AI Technology
AI Audio - Intelligent Audio-Sensing Technology
AI Net - Intelligent Net-Diagnosing Utility
AI Overclocking - Intelligent CPU Frequency Tuner
To create a user-friendly interface, ASUS introduced the Artificial Intelligence (AI) Series. These motherboards include automatic and intelligent features for Gbit LAN, 6-channel audio, BIOS recovery technology and more.
P4P800 Introduction
Fast solution for fast performance
Leveraging the Intel 865PE chipset to support 3.2 GHz+ P4 CPU on 800MHz FSB, Dual DDR 400 memory, Intel Hyper-Threading Technology, and a full-range of advanced features, P4P800 really delivers a full-value, high-performance solution for today's most demanding tasks.
Intel 865PE chipset
P4P800 Series support FSB 800 MHz up to 3.2 GHz+ P4 CPU and Intel Hyper-Threading Technology. They raise the bar of PC industry and deliver a full-value, high-performance solution for today's most demanding tasks.
Dual-Channel DDR400
Dual-channel DDR technology doubles the bandwidth of your system memory and hence boost the system performance to out perform any memory existing solutions in the market. System bottlenecks are eliminated with balanced architecture and peak bandwidths up to 6.4BG/s.
AI NET
The AI Series supports Gigabit LAN by integrating the 3COM 3C940 controller, equipped with a unique net-diagnosing Marvell utility-- VCT (Virtual Cable Tester). The controller intelligently detects net connection status up to 100 meters from a remote location and reports the distance of bad cable.
AGP8X
AGP8X (AGP 3.0) is the next generation VGA interface specification that enables enhanced graphics performance with high bandwidth speeds up to 2.12GB/s.
ICH5R with Integrated SATA and RAID 0
Intel is the world's first chipset maker to integrate Serial ATA (SATA) and RAID 0 functions into the South Bridge. The latest ICH5R chipset now delivers 150MB/s fast data transfer (SATA) and striping performance (RAID 0) to enhance computing efficiency. Note:Microsoft WinXP only.
Multi-language BIOS
ASUS provides friendly localized BIOS setup menu to help you configure your system as easy as possible.
* For multi-language BIOS, please visit the ASUS website for supported languages information.
AI AUDIO
AI series motherboards employed the world's first intelligent audio CODEC. The 6-channel AD1985 audio CODEC automatically detects and identifies what types of peripherals are plugged into the audio I/O jacks and notifies users of inappropriate connection, meaning there will be no more confusion of Line-in, Line-out and Mic jacks.
ASUS Q-Fan technology
This Asus unique technology intelligently adjusts CPU fan speeds according to system loading and temperature to ensure quiet, cool and efficient operation.
Max. 8 USB 2.0 ports supports
USB 2.0 is the latest connectivity standard for next generation components and peripherals. Backwards compatible with current USB 1.1 peripherals, USB 2.0 delivers transfer speeds up to 40 times faster at 480Mb/s, for easy connectivity and ultra-fast data transfers.
Extreme Overclocking
ASUS P4P800 offers robust overclocking options to maximize your system performance.
- Flexible CPU Core Voltage Adjustments in 0.025V increments over defaults
- SFS (Stepless Frequency Selection) at 1MHz increanerts
- Adjustable FSB/DDR ratio. Fixed AGP/PCI frequencies
- C.P.R.(CPU Parameter Recall)
Yeah, the Asus P4C800 is a good mobo with lots of O/C features including a setting to fix the PCI/AGP to default speed. This post should really be in the motherboard section.
I have the Asus board (This thread should be posted somewhere else) and it rocks....
Z
