Hello Xxxxx,
The Predator 360 would work just fine for cooling one CPU and one GPU. A good rule of thumb for watercooling is to have 120mm of radiator for each component and an additional 120mm per loop. By this logic, a Predator 360 would be perfect for one CPU and one GPU. Please feel free to contact us with any additional questions.
Thank you,
EKWB USA Support
Dec 10, 18:55
Thanks Ryan.
Will the Predator 360 support the overclocked CPU and the 980 ti GPU (probably overclocked)?
Thanks.
Hello Xxxxx,
Sadly we do not recommend ordering and adding 2x pre-filled GPU water block to the Predator unit.
This way you will not get the optimal performance from the unit and the QDC fittings are quite big and usually there is not enough space between the cards, so you will have a hard time fitting everything together.
To get a bit more information on the radiator size needed for the system, please read the following -
https://ekwb.zendesk.com/hc/en-us/articles/205235861-What-size-radiator-do-I-need-for-my-system-
If you would like to watercool 1xCPU + 2xGPU I would recommend getting a custom loop or one of our KITs and than you can simply add couple of needed products (additional radiator, fittings...) and you are set.
https://shop.ekwb.com/catalogsearch/result/index/?limit=36&q=ek-kit
Thank you,
EKWB USA Support
