I removed my Delta 38 from my case today. Thank the Big Bopper, the little sob now nestles in a cardboard box. When I removed the Alpha PEP-66 it's screwed on to, I discovered matt of dust on the bottom of the PEP-66. It almost covered the entire bottom surface of the fins. Way to go, klosters64a--your professionalism does you credit. Not!
Periodic shots of canned air don't do the trick, folks. I suggest that you remove your PEP-66 and check the bottom of the fins before summer sets in. Your CPU will thank you! Or just flip the fan and have it blow on the HS.
I installed a new FOP and tie-wrapped a 42.5 cfm Sunon 80mm to it. I'm using it on a Slocket, so two of my Dimm slots are blocked, but the Crucial 256 Mb Dimm only needs one slot.
My case cutting, fan installation, and banishment of the Delta from Hell-a are now complete. Can I get a "yaay?" Yaay!!
A ducted 60-80mm adapter to put an 80mm on the Alpha would probably be better than the setup I have now. Plastic ones are sold in Japan now, but they are very expensive, as well as very,--perhaps too tall. Dunno if there will ever be a US distributor.
