Is this 500w psu any good?
mikyseee
under a rock
I see the Leadman LP-6100E any good? The specs are:
500W ATX Switchable (115v or 230v) Power Supply
Available Wattage: 500 Watts
Low Noise Design
Short Circuit Protection
Over Voltage Protection
Thermal Overload Protection
Dual Ball Bearing Fans
Dimensions: 165mm (d) x 150mm (w) x 85mm (t)
Great for AMD Athlon Systems AND Pentium 4 Systems!
Recommended by AMD to Work with XP and MP Processors!!!
Voltage Specs: 3.3V-30A; 5.0V-50A; 12V-25A; -5V-0.3A; -12V-0.8A; 5Vsb-2.0A
NOTE: Specs are as listed on the Power Supply Directly
Includes an ATX Aux Power Connector (AKA Extended ATX), and ATX 12V Connector
You think I can run a pelt that need 24A on line +12v with this?
Z28
The Leadman LP-6100E is a very good power supply . My Abit KG7 1333 Tbird is overclocked to 1583 with 512 mb of ram ,5 120mm fans. 3 80mm fans GeForce 3 T1 450 2 hds, 1cd ,1 cdrw 40x12x48, santa cruz sound linksys LNE100TX 5V is 5.08 12v is 11.91 never drops lower:) :) :)
srwven
Pennsylvania
I have this ps. Just bought it and I like it. I was having low dips on my 300W. I have a 1133Tbird at 1.85V at 1283mhz with a geforce IImx400, 4 case fans. My 5.0 under load is 5.0, the 3.3 under load is 3.28.
