- Mar 2, 2002
- Denver Colo.
Here's the test report on CPU before it was sent to me today:
System Memory Controller
Location Mainboard
Error Correction Capability None
Number of Memory Slots 4
Maximum Installable Memory 2GB
Bank 1 - RIMM 1 RIMM RAMBUS DRAM 256MB/16 @ 800MHz
Bank 2 - RIMM 2 Empty
Bank 3 - RIMM 3 RIMM RAMBUS DRAM 256MB/16 @ 800MHz
Bank 4 - RIMM 4 Empty
System Chipset
Model Asustek Computer Inc 82850 (850) Processor to I/O Controller (MCH)
Bus(es) AGP PCI USB SMBus/i2c
Front Side Bus Speed 4x 133MHz (532MHz data rate)
ACPI PM Support Yes
APIC
Multiplier 1/2x
APIC IRQ Handler Engaged Yes
Logical/Chipset Memory Banks
Bank 0 Setting 128MB RDRAM 10-1-1-1R 8-1-1-1W 8/9CL
Bank 1 Setting 128MB RDRAM 10-1-1-1R 8-1-1-1W 8/9CL
Bank 2 Setting 128MB RDRAM 10-1-1-1R 8-1-1-1W 8/9CL
Bank 3 Setting 128MB RDRAM 10-1-1-1R 8-1-1-1W 8/9CL
Independent Memory Channels 2
Memory Bus Speed 532MHz
Memory Modules
Memory Module 1 Samsung MR16R 082GBN1-CK8 3AA59306 256MB/16 (128Mx16) RDRAM RIMM PC800 (CL2-2 upto 411MHz)
Memory Module 3 Samsung MR16R 082GBN1-CK8 3A179206 256MB/16 (128Mx16) RDRAM RIMM PC800 (CL2-2 upto 411MHz)
Environment Monitor(s)
Model Winbond W83782D
Version 3.01
Mainboard Specific Support Yes
Configured Mainboard
Level 4/5 Support Yes
Temperature Sensor(s)
Board Temperature 27.0°C / 80.6°F
CPU Temperature 28.0°C / 82.4°F
Cooling Device(s)
CPU Fan Speed 5273rpm
Voltage Sensor(s)
CPU Core Voltage 1.44V
Aux Voltage 1.78V
+3.3V Voltage 3.23V
+5V Voltage 5.00V
+12V Voltage 11.92V
-12V Voltage -11.62V
-5V Voltage -5.05V
AGP Bus
Version 2.00
Current Data Transfer Rate 4x
Side Band Enabled No
Side Band Support Yes
Fast-Writes Enabled Yes
Aperture Size 64MB
PCI Bus(es)
Version 2.10
No Buses 2
LPC/ISA Bus(es)
Model Intel Corporation 82801BA (ICH2) LPC Interface Controller
USB Bus(es)
Model Intel Corporation 82801BA/BAM (ICH2) USB Universal Host Controller
Version 1.10
UHCI Interface Yes
Channels 2
Bus Speed 48MHz
Legacy Emulation Enabled Yes
i2c/SMBus/BMB Bus(es)
Total/MB Channels 3 / 1
Version 0.04
CPU & BIOS Information
System BIOS
System BIOS
Manufacturer AT/AT COMPATIBLE
Date 12/12/01
Plug & Play Version 1.00
Processor 1
Processor(s)
Processor Intel(R) Pentium(R) 4 CPU 1.80GHz @ 2.41GHz
Co-Processor (FPU) Built-in
ALU / FPU Data Rates 2x / 1x
Type Standard
Performance Rating PR2887 (estimated)
Generation 7th (7x86)
Revision/Stepping 2 / 4
Caches
Internal Data Cache 8kB synchronous write-back (4-way, 32 byte line size)
Internal Trace Cache 12kµops synchronous write-back (4-way, 32 byte line size)
L2 On-board Cache 512kB synchronous ATC (8-way, 64 byte line size)
CPU Core Voltage 1.46V
The above Cpu was tested on a Austek, I will be putting the Cpu in a TH7 II with 512 Samsung PC800.
I bought this setup from reading most of the post here. I think BatBoy is a very informitive guy
Any advise would help.
Location Mainboard
System Chipset
ACPI PM Support Yes
APIC
Multiplier 1/2x
Memory Modules
Version 3.01
Cooling Device(s)
Voltage Sensor(s)
Aux Voltage 1.78V
+3.3V Voltage 3.23V
+5V Voltage 5.00V
+12V Voltage 11.92V
-5V Voltage -5.05V
AGP Bus
Version 2.00
Aperture Size 64MB
PCI Bus(es)
Version 2.10
No Buses 2
LPC/ISA Bus(es)
USB Bus(es)
Version 1.10
UHCI Interface Yes
Channels 2
Bus Speed 48MHz
Version 0.04
System BIOS
System BIOS
Date 12/12/01
Processor 1
Processor(s)
Type Standard
Caches
