- Dec 12, 2007
http://valid.x86-secret.com/show_oc.php?id=339374
I want a higher FSB. Help me. My goal is 4.3GHz. Setting the bar high
EDIT: It crashed about 45 seconds after I got all my screenies and validations.
You intend to run 24/7 ??
Most q6600 cant get that high w/o reasonable Vcore . What your NB ,VTT votlage setting at ?And also your RAM, what're you using ? More info please.
And your temp , I doubt it is under 75*C full load with air ..
Hopefully laterWater cooling!![]()
take off the heatsink and set 1.8v vcore
9 multiplier
500mhz fsb
do us all a favour and film it
12 seconds isnt long enough for a viable test, run P95 for 24 hours, and if you can do that without crashing, youre good. You'll probably end up with 3.8 Ghz at best without going phase cooling ect.
He means the safety mechanisms on the motherboard. Unless you disabled them, they are on. Plus, the CPU has a built in one that can not be turned offAlright, noob moment. Where is that an option? and what does it do besides....manage heat.
WRONG. LN2.Wrong. Phase change cooling.![]()
