Is this a good stepping??
I've never seen or heard of a stepping like this, this is still the T-Bred 'A' core tho, it might or might not OC better than the best stepping T-Bred 'A'. I think you would just have to try it out. the stepping that is known to get the highest overclocks on the Tbred 'A' is the AIRGA, you have RIRGA, I'd expect you would be getting more or less pretty much same speeds
What do you mean with T-bred A??
Thoroughbred cores come in two flavors, the earlier and typically less-overclockable version "A" and the later/newer and more overclockable version "B".
The part you listed is an "A" variety...
**I forget how you tell if it's a "B", I thought it was based on the revision code, but maybe it's the part number... :confused:
