- Sep 24, 2005
- Indianapolis
I've recently found a job, and that means I have money now, so I'm going to be getting a new gaming comp soon-ish. I just want a few people to comment on my choice of hardware, and since it's my first watercooling system, I want to make sure all the components for that are compatible. Just so you know, I'm going to be overclocking this thing like there's no tomorrow. And no I won't be buying it all at once. Most likely I'll just buy the stuff either when it goes on sale or I get enough money to buy all the remaining parts... I love not having to pay the bills, cuz it means I can spend my money on this stuff!
Case - This sexy thing (I mean that in a non-sexual way) $299.99 *is shot* I need the room so I don't have to buy a separate case for the watercooling stuff (although this is as big as 2 cases glued together ).
Power Supply - OCZ 520W Powerstream $119.99
CPU - Dual-core Opteron 165 $350.00
Mobo - DFI Lanparty Ultra-D $128.00
RAM - 2x1GB DDR500 Mushkin Redline $305.00
Video Card - eVGA Geforce 7800GT 256MB $299.00
Hard Drive - Maxtor DiamondMax 10 250GB SATA150 $99.00
CD Drives - NEC Silver IDE DVD Burner $40.99
ASUS Silver IDE DVD Drive $25.99 (Yes the drives need to match the case!)
Fan Controller - Sunbeam 5 1/4" 4 Channel Rheobus $19.99
Case Fans - 9 Thermaltake 120mm Blue LED Fans $6.99 x 9 = $62.91
Radiator Fans - 3 Panaflo 120mm Medium Speed Fans $10.99 x 3 = $32.97
Fan Grills - 9 120mm Metal Fan Guard $1.95 x 9 = $17.55
Fan Screws - 100 Chrome Fan Screws $5.00
(All items below with 1/2" OD fittings.)
Radiator - Black Ice Extreme III $77.99
Pump - Danger Den D5 Pump $74.95
Reservoir - Danger Den Dual 5 1/4" Bay Reservoir $31.95
CPU Waterblock - Swiftech Storm $63.95
GPU Waterblock - Danger Den NV-78 $124.95
Tubing - Tygon 1/2" ID 3/4" OD Tubing $2.80/3 ft. (How many feet do you think I'll need of this?)
Watercooling Fluid - PrimoChill PC ICE Non-Conductive Blue UV Reactive Liquid $19.99 (I know I could just use anti-freeze but I need my comp to glow as brightly as possible )
I know, I know, most people would say I have too many fans. Well I say I don't have enough! Even though it's watercooled, I want as many fans as possible (as long as they're quiet) just so I can brag about having more fans than everyone else! And don't ask for the total cost, I'm too lazy to add it all up...
