Is this a good Water-Cooling system?
just a suggestion, don't buy a kit. It's more expensive to do that. Just read up on the subject and buy the pieces separate. This website and many others have all the info you could want.
well your link dosent work and if you want to buy a full kit go witn danger den they have the best kits and have the best water blocks. Personally I think kits are a ripoff so I bought a danner mag 7 a heater core and a dd maze 2 and that cost about 70 and it works a lot better than any overpriced kit.
whiskeyinajar (Jul 16, 2001 04:10 p.m.):
Where did you find a Danner Mag 7 AND a Maze 2 for 70 bucks? That Maze 2 costs 40 bucks so the pump must have been 30? Where'd you buy that from? I'm looking to replace a Rio 180.
The Danger Den Maze-2 will cool a little better than any block out there. Just have fun and be creative. I to wouldn't recommend a kit since they cost more and you may not get exactly what you want. Do some research and see what's out there before you buy.
THank You, all you the help you have given me!
It helped ALOT!!
Thank You,
Anti_INTeL
When Overclockers was doing a lot of water cooling post their number one block was the one in the aquastealth kit. I am not saying an aquastealth kit is the best, but when they compared blocks from different manufactures, this block was the one they compared all of them too. I think it won every time.
Anyone have any internal pics of this unit ?
Yes I have an aqua stealth and the kit is crap but the block is good. Got my little tub with my pump.. The kit works fine but I am scared as hell of the pump. Everyone says they are junk...I don't know, it just pumps water, and has not died yet.
