Okay, I'm building an OP computer, and I'm going to be using a lot of money on liquid cooling. I will probably be overclocking if it becomes necessary in the future. I'm using my computer a lot, I'm pretty much using it everyday from when I get home from school to I go to bed. I usually do a lot of things that are CPU and GPU heavy, so it will probably get quite warm. So, I hope this liquid cooling will be great with the build I'm making atm.
Radiators:
Black Ice GTX Xtreme 240 Radiator
Black Ice GTX Xtreme 480 Radiator
Reservoir + pumps:
Koolance RP-401X2 Single 5.25" Reservoir w/ 2 PWM Pumps Installed (Rev 1.1)
(going to have 2 pumps in one loop, I guess I'm using this (Koolance 180-Degree Connector for RP-401X2) for that.
Fans:
Noiseblocker NB-eLoop B12-3 120mmx25mm Ultra Silent Bionic Blade Fan - 1900 RPM - 26.5 dBA
EDIT: GPU water block:
EVGA GeForce GTX 680 Classified Hydro Copper Waterblock
CPU water block:
EK Supremacy Universal CPU Liquid Cooling Block - Full Nickel (EK-Supremacy - Full Nickel)
Dual GPU connector:
Koolance Dual VID Connector - Adjustable 2-3 Slot Spacing
Liquid:
XSPC EC6 High Perfromance Liquid Cooling Premix Coolant - 2L
Tubes:
14 meters XSPC High Flex PVC Tubing - 1/2" ID (3/4"OD)
Nozzles:
Koolance 1/2" x 3/4" (13mm x 19mm) G1/4 Threaded Compression Nozzle
What kind of loop would be better? CPU - 240mm rad - GPUs -480mm rad? or GPU - 480mm rad - CPU - 240mm rad?
I think I'm going to be using the AZZA Genesis 9000, since the support at coolermaster said I couldn't use a 360mm rad with their Cosmos 2. And I don't really want the Cosmos 2 anyways. But do you guys recommend another chassis for a 240 and a 360/480mm rad?
Price matters to some extent, but I'll take a look at your suggestions no matter what it costs.
Is there anything more I need? Do you need anymore info?
Radiators:
Reservoir + pumps:
Fans:
CPU water block:
Dual GPU connector:
Liquid:
Tubes:
Nozzles:
