I have a Thermaltake case. http://www.thermaltake.com/products/cases/5000.htm I used to have five case fans, and a volcano 9. Two front fans would suck air in and two back fans would blow air out, while my side panel fan would suck air in. At load, while I played Tribes 2, I would be running 44C. Well I wanted to be the first dude on the block to have a watercooled pc, so I bought a watercooling system. I went super cheap and settled for the Iceberg 1 kit. Now when I run at full load I can reach up to 48C. I have the two front fans still sucking air in, and three back fans blowing air out, with my side panel fan sucking air in still. If you're not familiar with the iceberg 1 kit then check this out: http://overclockersclub.com/iceberg1watercoolingkitreviewtest.php#09 Now my main question would be: Did I basically buy this watercooling system just to reduce sound, and if I wanted a "cooler" system should I just stick with my Volcano 9? Also do I have the fans set up right in my case, or should some that are blowing be sucking, and so forth? And would it be worth putting my radiator outside my case, or just not worrying about all that, and put forth the money and buy something "nice"?? Any feedback would be greatly appreciated.
