is this ok spec?
Shock
Corsair 512MB DDR XMS3200 CAS2 (MY-007-CS) 1
Abit AT7-MAX2 (Socket A motherboard) (MB-023-AB) 1
AMD Athlon XP 'Thoroughbred' 2400+ (Socket A) OEM (CP-025-AM) 1
2 x Western Digital Caviar 80GB Special Edition (OEM) (HD-000-WD)
Sapphire ATI Radeon 9700 Atlantis Pro 128MB DDR DVI/TV (AGP) - Retail (GX-001-SP) 1
Thermalright SLK-800 (Socket A/FC-PGA) (HS-003-TR) 1
Fan Option - - Fan: YS-TECH FD8125 80mm Fan - 3 Pin (FG-001-YS) 1
thats what i be geting in 3 weeks, does it look ok or should i change make or somthing ?
will it overlock well ?
asj
Scotland
Damn that thing'll be fast! Just tell me how nice the mobo is cos thats the one I want! You could get away with just having PC2700 but that just means it won't OC as well!
1 problem it will generate alot of heat so I would suggest getting more 80mm fans!
Captain Slug
Helpful Senior Member
Asteroid B-612
Thermalright SLK-800 (Socket A / FC-PGA) (HS-003-TR) 1
Unless you're planning on putting that second heatsink in another system, you don't need two of them.
That's quite a beast and should overclock just fine
S
Shock
forgot 2 say i have 5 case fans atm , i be geting a 430 psu antec truepower
will that be 4 with this setup ?
S
Shock
mobo is £150 (me from uk)
cpu i am waiting 4 2400+ taking its time 2 come over here :(
asj
Scotland
Iam from the UK as well!!! No one really knows how good the XP 2400+ is so I would give it a little while, read more reviews and then make your mind up! But you have probably made it up already and want all that AMD power!!!! Iam I right?!!! lol!!! Don't worry we all make up our minds and then ask people!!! Its what us brits do!!! lol!!!!
S
Shock
i am still checking things out, like nf2 maybe out soon (if i am lucky) :-D
