Is this psu too cheap? HEC 585Watt
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
I dont believe HEC is a good brand at all. NEVER cheap out on the PSU. Something like a corsair 550VX would fit in that same power envelope just fine.
Also, there are no external links allowed in signatures. I would remove that before a not so forgiving moderator does it for you... :)
Marshmallow64
California
I would stay away from no name brand PSUs, the problems I hear about them in the long run are not worth it to skimp out 10-20 bucks.
Mr.Guvernment
cheap PSU's fold under load and usually take out your entire system with it...
Why people want to go cheap on the power supply is always beyond me, the PSU should be one of the most important and best quality pieces in any build.
atomic ferret
What he said.
I learned that lesson the hard way...twice.
kkpudge7
Michigan
Stay away from HeC... I had one once, its now a 750w paper weight (luckly didn't take my whole rig out, but the thing literally lasted about 3 months...) Corsair/pcpnc/OcZ ftw
Mr.Guvernment
any review that says it is good, the person is likely using it in some single core rig, or they dont tax their system at all, but do you really want to take the chance in the end.
i know people who have cheap PSU's that have lasted years, then the others who lost their whole rig with a simple power spike.
