- Mar 23, 2001
Could someone tell me whether or not a Little Giant Statuary Fountain Pump (model number 567022) with a 300GPH rating (I assume that's @ 1') will be a good enough pump to supply water to Danger Den's Maze2 Water Block, their Cooling Cube Radiator, and the video and chipset block? The block is being installed on top of a 156 watt pielter, if that makes a difference.
I found it for half price at Home Depot, so I figured I'd pick it up. If the general consensus is that it's not adequate then I'll return it.
Do you feel that an in-line pump would be better? Isn't it easier to remove the air from a system with a submersible pump? Finally, isn't the water temperature with a submersible pump in a reservoir cooler then the water in a closed loop system using an in-line pump?
Can you recommend a better pump? If this one is ok for now, what would be a good for the future?
Thank you for you assistance! Have a nice day!
Brian
Brian
