- Apr 2, 2002
- Ottawa, Canada
Im finding this hard to grasp.
Ok I have a Duron800 "o/c'ed" to 1000, multipler untouched, FBS upped from 100Mhz. to 124Mhz. And the core voltage from 1.60 to 1.85.
The way I see it I should be able to goto 133Mhz. FBS and stay within specs. My old AMD450/Aopen mobo ran at either 100 or 133 depending what kind of memory you had, I have 133 of corse. Ok I just had a memory lasp, I seem to remember something about 33 & 66 FBS, I think maybe a dual config 66/133 ? i would have to go thru all my old doc's (find them first!) to find my old mobo manual.
So from what I've researched AMD has turned the v-core volts down on the Duron (something to do with smaller cache and locking it?!), and the Duron can easly handle 1.85 v core voltage (also within spec's.). 133Mhz. front side bus is also within spec's on the Duron or any AMD Duron and up processor for that matter.
Yes I know the fact is... If you modify your system from factory setup then your overclocking but...
How am I stressing my system ?
I must be missing something here !
So i say it again...
Is it really overclocking ?
Thanks
Wayne
<<<alpha sig test>>>
My main Rig:
[email protected] L7 1.85v mod 8x124Mhz. FBS.
ECS K7S5A. Mobo30c/CPU 40c idle 45c max.
Cidicom 5E34B3-HH cpu cooler for AMD & Thermal grease.
250w PSU (noname) 3.3&5v=100/[email protected]/15a.
Georce2 MX 400 32meg XP detonator 28.32 drvs.
SoundBlaster Live Value 1024.
Aopen 8x8x32 CDR/CDWR.
Fujitsu 20gig 5500rpm H/D.
2 3" 12v case fans [email protected] mod, H/D cooler/twin fans, Geforce HSF.
CH Flight Sim Yoke & Pro Peddles.
Windows 98se/Windows 2000pro dual boot system.
<<<alpha sig test complete>>>
Thanks
Wayne
My main Rig:
