I was having problems with a 1.1ghz on Asus A7V with a chrome orb cooler. It was running hot I guess at 62c (temp from bios so I assume it wasn't even at full load) so I cleaned the stock thermal pad off and used some radioshack thermal grease. The computer was idling at 50 and it went as high as 58 when I was playing games for a while. The 58 had me worried so my friend suggested I use my room fan to cool of the motherboard. I pulled the panel off of the case angled it 45 degrees to the 14 inch windmere room fan (with remote control!) and turned it on high. Within two minutes my cpu temp dropped from 58 to around 47c, now it idles around 45 with the fan on..
My question: Is this safe to have your case open and a big *** fan blowing on it? There is a lot of air flow now, and I am worried that the dust may damage the board or something. Besides I would rather not have this setup, but Im not sure the best fan to replace my chrome orb.. (probably global win fop38)
