Not necessarily. You can have a vcore that high safely as long as the temp doesnt get too high: ~55C. I would monitor it closely at that voltage though, and make sure your PSU can handle it.
Safe maybe will the cpu last as long as you want it to prabably not. If temp's are 30c no more @ full load with 2.0 volts you might be alright the chip may last 3 yr's then again it may last 3 hour's. I have ran my 2100 @ 2.1 volts' before but only to see how high (MHZ) I could load window's @. I think that anything over 1.85 volt's or 25% voltage increase is alittle to much depending on the temp. I myself hate seeing my temp's break 40c but most people will say that 50c is ok.
Define 'safe'. Running increased voltage always increases risk. Increased cooling reduces risk. How much the increased voltage will cause a problem depends on the processor. What is the default voltage? What process is used to make it? What core does it have? I'd feel much better running a 1.75v Pally at 2v than a 1.5volt tbred.
