Is this viable?
Spyral
I'm just wondering if this is viable...
Club 3D Radeon HD4850 1024
4 GB DDR3
AMD Athalon II x4 630 - or I'm thinking of bumping it down to the AMD 250 2x3Hz which is cheaper, but 'faster' for the mostly single core old stuff I'd be running. Also I don't know what I'd have that would use 4x cores...
ASUS m4a77TD
I have a hdd, dvd drive case etc. Need to get a PSU but aside from that any ideas?
would this run oblivion fine? Any choking? need moar ram?
Theocnoob
Near Toronto Canada
Never heard of Club 3D.
I'd really suggest taking the hit and getting a 955 or atleast 945 if you build an AM2+ or AM3 system.
It'll run two instances of Oblivion side by side. At reasonable rates.
Also given the cheapness thereof nowadays, can you find a cheap 4870 1GB? It'll be a nice little boost.
What is your budget with taxes all in?
Maybe someone can suggest something better?
Spyral
Spyral
My budgt is about £400 but I have my own case , dvd drive and peripherals. I was thinking about £100 each on mobo, cpu and gfx card + ram
