- Aug 27, 2001
- Dark side of hell
I have seen post after post complaining that there board gives inacurate temps. This is a known fact and even if it is a just released board it still should not upset you. The reason it shouldn't is that the insocket temp probe is not acurate and is there to give you an idea of your temp. Like if you normally run at 45 and you are running at 65 then you know something is wrong. The only way to get a true temp is to do it yourself with an external probe placed against the core. (Not in between the core and the heatsink
)!!! Until they start making motherboards that can read the internal diode in the XP chips this is the only way to get a good temp reading. My advice is to get a compunurse or senfu probe. When you first set your system up and are burning it in. use the probe to see what the difference is between your insocket probe and the compunurse is. Then just adjust your Motherboard Monitor 5 to add or subtract the difference. Then you can take the compunurse out. Do not forget to redo this everytime you take the chip out and whenever you do a bios flash. thanks for reading my rant
Edit: you should also recheck after a bios flash!!!!!!
Kenny
Kenny
