Ok I recently started getting the big bad B.O.D stop: errors so I figured the easy way to solve this would be to format and start fresh..Well I reformatted and got another B.O.D!! The only new software I installed was the new version of zonealarm pro 3.0(never had problem with the old version) I was starting to think it was a hardware problem but I now I think it might be ZA.
well here is the odd thing almost every blue screen had a different error message . ...
IRQL_NOT_LESS_OR_EQUAL <------ got this error a few times with different stop: codes
BAD_SYSTEM_CONFIG_INFO <-------- got this one once then I formatted
PAGE_FAULT_IN_NON_PAGED_AREA <----1st error after format
Process_has_locked_pages <-----2nd error after format
any one having the same problems or do you think its a hardware issue ?
