Hello All,
TIA.
Need a little advice. Not sure what is going on. My main monitor is the 4k tv in my sig. I had a secondary monitor, but it recently died. Didn't have any issues for weeks after unplugging the dead monitor, but now windows is not filling the screen when I lower the resolution from 4K.
Sig is current. And yes i know, the massive bottleneck is my video card. GPU prices are finally coming down so I can finally look at that... Anyway. The out dated GPU is why I prefer to run windows @ 2560x1440 resolution. This way I can winow mode my games that are @ 1920x1080. It gives me a good balance between FPS and the ability to multitask / keeps me from getting sucked into games for hours on end when I don't want to.
On to the issue at hand. I noticed in my gpu properties, it was only showing 59hz refresh rate. which is fine, but i wanted to bump it up to the full 60hz. when I changed that.. all of a sudden Win10 in the 2560x1440 resolution that's been fine forever decides to shrink down and center itself in the screen. I don't know if this is an upscaling issue or what, but its like windows recognizes the max resolution capable of the monitor, and only displays a 2560x1440 window centered in a 3840x2160 area. Freakin wierd. And frustrating. Got some pics, but I had to take them with my phone because the screen shots were only capturing the 2560x1440 window, and not the dead screen space around it.
These are the display settings from the shot above. Notice Multiple Displays: I have it set to Show Only 1. I'll get to that in just a second.
Here's where it gets really wierd. I took my dead monitor, and hooked it up to the DVI port. and BAM. the 2560x1440 res fills my screen again. Here's the pic
If you notice in this last pic. the Multiple Displays is set to Extend These Displays.
I can duplicate the issue by hooking up that dead monitor, and chaning that multiple display setting. When it thinks there are 2 monitors, its fine. But if its just the 4k TV alone, the only resolution that will fill the entire screen is 3840x2160 or the 1 step above that. Which is just too taxing on my video card.
The end goal is to be able to run Win10 @ 2560x1440 and have it fill the screen with only my tv hooked up.
Thanks again for any help or insight. And sorry if this is posted in the wrong section.
TIA.
