Issue??? with running stress test
Dhampir
New Zealand
Hello all,
Running stress test, Stable CPU at 4214.06 MHz, Voltage 1.368
Bumped it up a little bit (not sure on exact settings) and came up with Warning "Illegal SUMOUT"
I'm wondering what this means
D
Dhampir
New Zealand
Prime95 Blended test on 8 threads.
it is now coming back with a "Fatal Error" "Rounding was 0.484375, expected less than 0.4"
this is on a 4.5GHz and 1.475v CPU and 1.3..? i think CPU/NB Voltage.
Rather new to this, OC'ing a GPU is so much easier. haha
ShrimpBrime
~MadHatDeLidder~
Cpu-z (All tabs) screen shots say a million words. Include the temperatures as well please.
ShrimpBrime
~MadHatDeLidder~
Ok you want to put cpu/nb back to stock values and not on auto. Enter it manually.
Manually set the memory timings also the memory voltage. Kick it up to 1.55v.
Needs a fan on the VRM to the left of the cpu socket there. It will help your temps. So will lowering the cpu/nb. Your not OCing ram atm...
And lastly when I see memory running 791mhz and not 800, it either needs a good cmos clearing or mix matched memory.
- - - Updated - - -
In fact I would pull 2 sticks of memory. 32GB is really over kill.
D
Dhampir
New Zealand
Ok, Firstly, what do I need to set the Memory Timings to?
Second, No ability to put a fan specifically on VRAM, it's not a test bench. but I do have 2 fans on my Hyper 212
and C, I shall remove 2 sticks... for now... I do Video/Image editing and Live streaming. but I likely can keep them out. leave them as spares
Edit: Please post exactly which Options in "Timings" needs to be set to what. Remember, I'm new to CPU OC'ing
Bluefalcon13
Colorado Springs, CO
It's not terrible... I wouldn't recommend it, but I had my R1.0 for a long while with a decent overclock on a 955. 4.2ghz on an 8xxx should be doable, but I'd say anymore is pushing it and I'd be a bit concerned about letting the blue smoke outta the blue smoke container...
trents
Senior Member
He suggested putting a fan on the VRM (Voltge Reguluation Module) not the VRAM. Two different things. The VRM is covered by a heat sink that lies between the CPU socket and the I/O ports at the back edge of the motherboard. We find that this can really help stabilize an overclock when the thermal envelope of the VRM is pushed to the edge. A 50 mm spot fan is about the right size. You can fasten them to the heat sink with double-sided adhesive strips or with zip ties.
D
Dhampir
New Zealand
Ok i've managed to get a Stable OC on 4.3, anything higher causes temps to go through the roof for some reason.
Thanks to ShrimpBrime and Bluefalcon13
