- Oct 3, 2011
so I got two 7970
I put one in my brothers and one in my computer
I tried both in both computer same issue
its has black Block on the monitor sometimes when at load however does not seem to do when gaming only BTC mining but it was only tested in WOT so maybe gaming also
temps are good both stay under 70c
could it be drivers? im running 13.1 for both
I could not see both cards being bad
also for my computer I did a clean install few days ago so it had no CCC from the 6970 only plug n play drivers think that could be it?
but with bro comp it had CCC 12.6 and uninstalled and than took the 5870 out and put the 7970 in
I will try to get a pic of it but it comes and go fast but its the Same issue with both computers im thinking bad drivers or it downloaded bad or its 13.1 just bad?
my computer specs
Motherboard: ASRock 890GX Pro3 Socket AM3+ 890GX ATX AMD Motherboard
CPU: AMD Phenom II X6 1100T Black Edition Six Core running at 4.0Ghz with 1.385v
CPU cooler: Corsair Hydro Series H100 Liquid CPU Cooler (4 fans)
GPU: Sapphire HD 7970 3GB OC Dual-X Video Card Driver 13.1
RAM: Corsair XMS3 16GB (4x 4GB) PC3-10666 1333MHz DDR3
OS: Windows 7 X64
PSU : InWin Glacier 900W 80+ Gold Power Supply
HDD: (2tb)
SDD: OCZ Agility 3 120GB SATA III
Case: Haf 932 adv
Monitor res: 2560x1440
brother specs
Motherboard: Giga EP43 UD3L s775
CPU: Intel Core 2 Quad Q6600 at stock speeds
CPU cooler: XIGMATEK HDT-S1283
GPU: XFX Radeon HD 7970 FX797ATDFC Video Card Driver 13.1
RAM1: 8gb (4x2gb) of default ram
OS: Windows 7 X64
PSU : 520w antec eco? (got it from bob forget what it is but tis good)
HDD1: (320gb)
Monitor res: 1280x1024
my computer specs
OS: Windows 7 X64
HDD: (2tb)
Case: Haf 932 adv
brother specs
OS: Windows 7 X64
HDD1: (320gb)
