IT7 MAX2 v2.0 SATA issue
lbbo2002
Houston, Texas
I am using the IT7 Max 2 v2.0 with 3 hard drives. 2 120 Western Digital 8meg cache in RAID 0 (IDE 3 and 4 - 32K cluster) and a DiamondMax Plus 60 Ultra ATA 100 40 gig w/serial adaptor on SATA J3. All drives are NTFS partitions, default cluster size.
I have the Maxtor as the windows O/S XP boot partition (95% free). The swap file is set to a gig going to RAID 0.
Under Sandra and PCMark I get crappy disk performance numbers. The Raid 0 Rocks but I can't seem to find what the issues is on the SATA.
In XP the controller shows ATA 100 and DMA is set correctly but I am stumped. I get like 659 in PCMark disk score and 20K in Sandra . This is drive is Maxtor 5T040H4 which is a 7200 rpm drive getting 5400 performance numbers . The RAID is 59000K Sandra so thats rockin.
Any clues? Anyone else seen this?
microfire
If your using an aftermarket soundcard then theres your problem.
IT7 + raid + after market soundcard = big problems.
It gets worse when you run more than 2 drives on the raid controller. Don't be surprised if your system locks up and expect it to be slow performance.
Im running 2 drives on the controller, its alot better than when I was running 4 drives. Even now I still have problems.
Put out your sound card and your numbers will go up. I know it sucks but its the only way.
lbbo2002
lbbo2002
Houston, Texas
I wish it was a sound card but I am using the onboard sound. The only card in it is the Abit G4 4200. That's what is confusing. I have read about the sound issue and before I got this board I decided to use everything on board. It comes with a dishwasher and everything :)
Anyone else... Any pointers?
The IT7 been out a while no one else hit this?
I hate it when I am the only one :eek:
