IT7 memory voltage regulator and modification
Natedog
I have been doing research for the last week on doing a volt mod and have come up with the volatge regulator for the memory on an IT7 being a FAN5063. Can anyone confirm this? Also where would I put the resistors, what should the resistance be(potentiometer) to get 3.1-3.2V. And before anyone says anything, NO the modded bios's wont let you actually go above 2.9 no matter what you set them to.
Blue078
Dallas TX
With the moded BT BIOS at 3.2vdimm I get 3.1v actule.
I measured pin1 in the dimm slot with a DVOM.
Abits hardware monitior app, and PC health in the BIOS say 2.96v
but I belive the DVOM and dimm slot measurement.
N
Natedog
I can get 2.96 in MBM5 but when you apply load it drops to 2.90-2.91V and load is where it really matters not at idle.
Blue078
Dallas TX
Yes I agree 100% load is were it matters.
With the DVOM I'm not seeing those kinda fluctuations, though.
Through the software yes, but actule readings with a good Fluke Meter say it's the software is off.
N
Natedog
hum ill have to look more into that. have you tried it at lower voltages like 2.8 to see if the DVOM measures the same as the software then
