- May 24, 2001
- Maine, USA
MY system appears to be getting worse. I try to open some programs and I get an immediate error. PLease read my previous post for additional info. ( AsusA7m266/Can't get passed 1.39Ghz...)
JEFF (Jul 06, 2001 09:23 a.m.):
ok first get rid of the errors.if you have 98 use dr. watson.(it may be in other windoze)go to help type in dr it will bring up dr watson click on display,click on snapshot,this should put him on the task bar.double click on him,he will tell you what progs have changed win files and may givr insight to your probs.
go to help type in system,look down to system file checker,click display,click run system file checker.it will show u all the windows files that have been altered.look for 32dll. files.compare files by kb size.most changes are ok but if corrupt it will ask for windows cd to reinstall that file.if not sure if file was updated click ignore so it will bring up again later on another check.good luck!
Looks like a very fine choiceBlue Jester_2112 (Jul 07, 2001 02:20 p.m.):
Check your memory, my father was having the same problems and it turned out to be bad memory. He tried everything you have, clocking back, reformating, even a low level format, once he pulled out his memory and replaced it with another stick everything ran fine again.
