its your ram causing it. for some reason XP doesnt like any form of mem errors. run memtest86 for an all scan for like 8hrs. ill bet youll generate errors. back off to default and they should (the errors) go away.
Dave65 said:Ok thanks guys I will give it a shot,I reloaded ME and I be damned it did it also just in a different way,ME just freezes up and then I reboot and errors messages come up,so I am going to just load them both and I am going to get a single copy of either XP Pro or 2000,I think the ME is the cause,but when I add the update XP it is picking up on the corrupt files,I shouln't of waisted the money on the update and just bought the full copy of Pro..
RhoXS said:I have been experiencing a very similar problem. Although I have no proven resolution, I hope what follows may help.
I did a clean install of XP early last November. It ran great for 3 weeks before the mysterious crashes started. The crashes invariably occur with one or both of two characteristics. Sometimes, without warning, the machine will boot into the BSOD. There is usually some message about a corrupted registry or hive file. At other times, again without warning, the machine will simply lock up. While rebooting, chkdsk finds literally hundreds of crosslinked/orphan files. In both cases it is necessary to reload XP from scratch.
I now have a removable hard drive and regularly clone/Ghost my main HDD so I have a relatively easy and fast recovery path. Although the back up drive is physically removed from the machine when I am not backing up my main drive, on one occassion it too became corrupted beyond repair during the short period it was in its slot.
In an attempt to find the cause of the problem, I have changed out every piece of hardware (CPU, mobo, SCSI, modem,sound card, NIC, video capture card, graphics card, HDD, memory, and power supply). The only thing that remains is the CD-RW and DVD drives. Here is what I have learned.
If you search the user forums you will find a small number of reports of people having this identical problem. However, it is rare and most XP installations seem to run fine. No one, other than those few people experiencing this problem believe there is a problem with XP.
When the problem first became apparent it was occurring so frequently I used the Microsoft pay per incident support number. We discovered that my Adaptec 2910 SCSI card was not XP approved. Changing it out for an Adaptec 2930 immediately significantly reduced the frequency of these crashes but certainly did not eliminate them. Obviously XP has the capability of responding in a very unwelcome manner to unapproved hardware. The Microsoft tech acknowledge he had much circumstantial evidence from logs of other calls to support the claims of nasty behavior with some hardware.
Changing out all the hardware (after the SCSI card) did nothing to reduce the frequency of these events. I am now running an ABIT TH7-II, a 1.8 Gig Northwood, and Samsung RDRAM at 117 MHz FSB(2.1GIG). It now appears, but I am not yet 100% sure, that the crashes do not occur limiting the FSB to 117 MHz. It seems if I increase the FSB to 120 MHz these destructive crashes again become a problem, even though the machine seems to run completely stable at 100% CPU load (SETI) for days at this speed.
I hope this might prove usefull.
The culprit could possibly be your IBM HDD I had the same thing happen and thought it was my ram. I had to reinstall my OS 10 times! Almost every time I raised my FSB the data got corrupt to the point were the computer couldn't even recognize the partition type . I switched the memory out of another rig I was building and encountered the same problem. Then I ran the IBM HDD test and got a error code and needless to say 2 days later It happened again this time the drive completely died. Since I got my new drive everything is smooth as butter.Dave65 said:I keep getting corrupted files with XP,I can't figure it out,so I reformated AGAIN and just loaded ME and I won't load the XP
I never had any of this with ME![]()
Malakai said:[
and rodgerdugans] Thats what u get for not immediately formatting and reinstalling windows ona storebaught pc. they cram so much "usefull software"(crap) onto oem's they never work till a nice fresh format to clean her up
keep the comments coming, and dave, please use that proggie, itll help me help u a lot
-Malakai [/B]
rogerdugans said:
Not for nothing, but while I did not do a clean install immediately after receiving the laptop, I have done about 14 or 15 since then!
Including fdisk from a boot floppy to completeley eradicate the previous install.
I am thoroughly convinced at this point that there are two operating systems that MS should never have released: Windows ME (More Errors) and Windows XP (eXtra Problems.)
I've heard all kinds of opinions on this subject, and I don't expect to change anyones mind, but if anyone is considering actually BUYING XP, please consider carefully! Windows 95a has proven itself to me as a better os, and it was pretty bad!
