- Mar 1, 2013
Ok so here goes, im new to the forum, and i dont know much about this stuff, but i have acquired an Intel Genuine Ivy Bridge processor (ES), i was told it was a downclocked 3770, but i have no way to be sure what it actually is. Its clock speed is 2.2 idle and 2.5 using turbo boost. Under load the temp for this chip is never above 40-45 C.
The guy i bought it from said he had it stable at 4 ghz, however when i go to overclock it the multiplier only goes up to x26. So does that mean the max i can overclock this chip is 2.6 GHZ? There is an option to raise the BCLK in the motherboard, but i dont fully understand how that works so i havnt messed with it.
I want to say the chip does everything i need it to right now, and i realistically dont NEED to OC it, but i would really like to. I have an ASrock Extreme4 Mobo and a GTX 560TI 448, 8 gig memory (only 1300mhz). I ran 3d mark11 and the score was only 6150 or something, i have seen people with similar systems but with higher clocked processors get almost twice that score.
Anyways i guess all that to ask if anyone has any ideas on how i can get the most out of this processor? Especially with it being a ES and not the norm. I will post CPUID or any other diagnostic info you may need tonight if it will help figure this thing out! Just let me know what you need.
Thanks!
Thanks!
