A friend just got the IWill KA-266R and I am helping him set it up. The only problem: It won't boot.
We have the KA-266R with 128 Meg PC 2100 from Mushkin pluged in. The cpu and heatsink/fan are attached just fine as is the Video Card. I have all the connectors (power, reset ...) connected with a hard drive and floppy hooked up right.
Power on... A green light comes on in the motherboard, the heatsink fan starts spinning, the floppy light goes on (does not go off) and the HDD makes a few cycles just because it was powered on. (If I remove the IDE cable, it does the exact same thing.)
The problem: Nothing comes up on the monitor. Just the usual "Monitor working, check the computer and video cable." I have the hard drive set to master on IDE0, and can't think of anything.
Any ideas?
I have also played with the jumper settings for raid, CPU FSB, and so on with no luck.
The two things I am currently thinking...
1.) I have noticed that the reset button does not do anything. I have checked the connection a hundred times and it is on the right pins. Might this stop the machine from going further?
2.) In the user manual it says: "KA-266 / KA-266R only support synchronous CPU & memory speed." This could be our problem. First, the Thunderbird is only 200 FSB. As for the Memory, well it is PC2100 which is 266 FSB. So I throw an unlocked processor in the motherboard, and get the same thing. Sure I could set the ratio jumper to 8.5, but it is not like this will give us a FSB of 133 for the processor. This I have to change in BIOS.... I think this could be the problem, but who knows!
Rebies
Any ideas?
Rebies
