mrkalohea (Apr 17, 2001 08:03 p.m.):
Just got my Iwill kk266-R, set it up and everything worked perfectly, until I had to reset the CMOS. I jumpered pins 2-3 then set it back to 1-2. Turned on the computer and all I get is BIOS Rom Checksum error. Does anyone know what happened.
Nomis (Apr 17, 2001 09:43 p.m.):
Try unplug the motherboard power connector and wait a while then plug it back in. Clear the cmos again and see if it will start.
Nomis (Apr 18, 2001 03:28 a.m.):
Rev1.1 don't have any problem with the board, only some of the Rev1.2 KK266 does. Something else to try? I think the FSB jumper labeled ....quote]
I tried your suggestions, no luck. I talked to Iwill and they told me I should RMA the board. Not sure if I should do that or just get a new bios chip. Does anyone know how this could have happened. After I changed the fsb to 120, it didn't post. I turned the switch on the power supply off, cleared the CMOS, turned the switch back on and then this.
Thanks all for the help!
mrkalohea (Apr 18, 2001 02:08 a.m.):
Tryed this. Left it unplugged for at about an hour, then plugged it back in and i still have the same problem. Another thing I didn' t mention earlier, After the Bios rom checksum error, it says
"Detecting drive A media...
Drive A error. System Hault"
or sometimes
Invalid media. Insert system disk and press enter."
